Change TextBox DataField at runtime
Posted by: softcomlimited on 6 August 2019, 12:56 pm EST
    Posted 6 August 2019, 12:56 pm EST
    I have a v12 Section report with all the textbox bound to a SQL query. I want to be able to change the setup of the report at runtime, changing the DataField of one of the textboxes from query column A to query column B, depending on a condition in the ReportStart.
    My alternative is to have 2 separate sets of fields (detail and summary) and hide the A fields or B fields based on the condition.
    Brian
  • Posted 7 August 2019, 7:34 am EST
    Hello Brian,
    If the condition that you use is predefined (i.e., not based on data value from the report), you can achieve both of the mentioned requirements in the ReportStart. For example, you can set the DataField conditionally as follows:
    int i = 5, j = 10;
    if (i > j)
    textBox3.DataField = “CustomerId”;
    else
    textBox3.DataField = “Country”;
    If the condition is based on the report related values, you can achieve the requirement to hide controls conditionally in Detail.Format event as follows:
    private void detail_Format(object sender, EventArgs e)
    if (textBox1.Value.ToString().StartsWith(“B”) || textBox1.Value.ToString().StartsWith(“D”))
    textBox3.Visible = true;
    textBox4.Visible = false;
    else
    textBox3.Visible = false;
    textBox4.Visible = true;
    A sample has been attached for your reference.
    [zip filename="SectionReport_Runtime.zip"]https://gccontent.blob.core.windows.net/forum-uploads/file-5ca7bcf8-04f1-4936-8251-22eb53be9a65.zip[/zip]
  • Posted 7 August 2019, 5:40 pm EST
    Ms Dhir,
    I had tried exactly these same 2 methods and only the 2nd was working. But the first is what I really wanted.
    After some checking I think the first was not working for me because I was looking for a value in a textbox and it was not populating as yet. I will have to get the value from the datasource directly instead.
    Thank you very much
    Brian Morris
  • Posted 14 May 2021, 3:20 pm EST
    Hi! I have the following problem, I want to send the value of the TextBoxPremio to TextBoxPremio2. The way it is done, it does not take that value to print it. Can you help me?
    <?xml version="1.0" encoding="UTF-8"?>
  • Posted 18 May 2021, 12:14 am EST
    You can use the Format event of the Detail Section to achieve your requirement:
    public void Detail_Format()
    	this.TextBoxPremio2.Text = this.TextBoxPremio.Text;
    Please refer to the modified image.
    ytest.zip
