Changing datasource in designer at runtime
Posted by: darin on 9 November 2022, 9:47 am EST
    Posted 9 November 2022, 9:47 am EST
    We have our program setup so when the designer opens, we set the connectionstring and load the datasource.
    Try
    Dim ds As New GrapeCity.ActiveReports.Data.SqlDBDataSource
    ds = CType(reportDesigner.Report.DataSource, GrapeCity.ActiveReports.Data.SqlDBDataSource)
    ds.ConnectionString = ConnectString()
    ds.SQL = "SELECT TOP 5 * FROM Customer WITH (NOLOCK)"
    reportDesigner.Report.DataSource = ds
    Catch oExcept As Exception
    MsgBox(oExcept.Message)
    End Try
    But, this fails and displays the message:
    Not allowed to change the ‘ConnectionString’ property. The connection’s current state is open.
    How can i close the current state to get the correct connection string and datasource loaded?
  • Posted 11 November 2022, 3:34 am EST
    Hi Darin,
    I tested this issue out with ActiveReports 16.2.1 EndUserDesigner Sample and I wasn’t able to replicate this behavior at my end. I have attached the sample application for reference.
    In the attached sample, I am changing the DataSource’s connectionString on ReportLoad and on ReportClear type Designer layout change. And, I was able to successfully change the Connection String.
    Please refer to the attached sample. If the issue still persists please share a sample application replicating the issue or edit the attached sample such that it reproduces this issue and send it back to us for further investigation on this.
    Akshay
    DataSourceChange.zip
  • Posted 11 November 2022, 7:20 am EST
    Thank you. That seems to be working. I was changing it in the wrong place. Appreciate your help.
