Chart fails after AR17 upgrade
Posted by: snellcb on 10 March 2023, 2:41 pm EST
    Posted 10 March 2023, 2:41 pm EST - Updated 10 March 2023, 2:46 pm EST
    After upgrading from AR14 to AR17.0.1, a chart report is failing at runtime. I’ve attached an example project and screenshot of the exception that gets rendered instead of the chart. Note that the chart in the example works if only the first item in the data array is added to the series, otherwise it fails. In my project I’ve seen the chart sometimes work when several points are in the series but it’s inconsistent. This in VS2019 with .NET 4.8 using section report having a chart control.
    Chart_NET48_VS2019.zip
  • Posted 13 March 2023, 4:42 am EST
    Hi Charles,
    Thanks for pointing this out to us. I was able to replicate this behavior at my end. I have escalated this behavior to the development team and will get back to you once I have any information on the same.[AR-30428]
    Akshay
  • Posted 28 March 2023, 12:50 am EST
    Hi Charles,
    We have fixed this issue in the latest version of ActiveReports 17 i.e. ActiveReports 17.0.2.
    Please upgrade your application to ActiveReports 17.0.2 to consume the latest hotfix. You may use the following link to download ActiveReports 17.0.2: Download
    Akshay
  • Posted 31 March 2023, 2:29 pm EST
    Thanks for the update. Version 17.0.2 resolved the pie chart issue for me.
    Chuck
