Posted 14 September 2017, 7:10 pm EST
[activereports_archive]I’m developing a PDF report using ActiveReports 10 for a .Net MVC 4.5 web application to be hosted on an IIS site. I’m attempting to use a few custom true type fonts (.TTF) within the report. During development on my local development machine the fonts are correctly rendered (hosted using visual studio IIS express). However when I have attempted to host the application on a IIS test server (Windows 2012 server with IIS 8) and the custom fonts failed to render and instead the default fonts were used instead. This issue also occurs if I host the application on a local instance of IIS.
I’ve installed the .ttf fonts on the test server but this failed to address the problem. I’ve created this report as a ‘Section’ Report also using the PDFExport component. Please could you point me the direction to fix this issue?
Gary[/activereports_archive]
