CustomControl does not contain a definition for BackColor
Posted by: sam.boustani on 28 May 2021, 3:59 pm EST
  • Posted 28 May 2021, 3:59 pm EST
    After upgrading ActiveReports from v11 to v15, the CustomControl.Control object no longer has a BackColor property.
    CustomControl customControl = new CustomControl(typeof(System.Windows.Forms.Panel));
    customControl.Control.BackColor = …
    What has changed and how do I access the BackColor of this object in v15?
  • Posted 31 May 2021, 1:35 am EST
    Can you change the BackColor using the following code:
    Panel Panel1 = (Panel) customControl.Control;
    Panel1.BackColor= Color.Redl
  • Posted 1 June 2021, 10:42 am EST
    Thank you. Here is the full code. I’m trying to set it to another controls BackColor
    if (a_control is CustomControl)
                   CustomControl control = (CustomControl)a_control;
                   customControl.Control.BackColor = control.Control.BackColor;
                   newControl = customControl;
    This conversion works
    Panel panel1 = (Panel)customControl.Control;
    However, I still can’t set it to the other control’s BackColor because that conversion does not work, or I’m not sure how to do that conversion.
    panel1.BackColor = control.Control.BackColor;
  • Posted 2 June 2021, 1:10 am EST
    Can you try after using the following code:
    Control ctr= (Control)control.Control;
    panel1.BackColor = ctr.BackColor;
    If issue still reproducible, please share the sample with us.
