CustomStore method called multiple times
Posted by: mike.killey on 16 December 2020, 11:23 am EST
    Posted 16 December 2020, 11:23 am EST
    I am using the CustomStore option so that I can load reports dynamically and interject parameters etc.
    I’ve noticed that the custom store implementation method I’ve defined is called three times from the JSViewer - firstly /info, then /render and finally there is /values.
    Could you please tell me what is expected from each of these URL calls? I’m hoping to pre-populate a number of dynamic parameters within the report (the ‘from query’ of report parameters does not seem to work as expected), but don’t want to be fetching data and injecting it into the report on all three URL calls made to the custom store GetReport method. I’d prefer to be returning the bare minimum each time that method is called. Currently I am loading the report file into a PageReport, adding dynamic parameters, then returning the PageReport.Report property. This all works fine, but I’d like to streamline and reduce database calls.
  • Posted 17 December 2020, 6:34 am EST
    Currently, the ReportsService.GetReport() method is called during the processing of the following requests:
    "/reports/
    {reportId}/info" (get the report descriptor)
    “/reports/{reportId}
    /values” (get the report parameters values)
    "/reports/
    {reportId}/render" (start render report)
    "/reports/{reportId}
    /export/
    {exportType}
    " (export report)
    All these requests are processed independently and report data is not cached.
    To overcome this, you can cache the report at your end by using the following of code:
    app.UseReporting(settings =>
               var cache = new MemoryCache(new MemoryCacheOptions { SizeLimit = 10000 });
               settings.UseCustomStore(reportId =>
                   return cache.GetOrCreate(reportId, entry =>
                       var reportFile = new FileInfo(Path.Combine(FileStoreReportsPath, reportId));
                       entry.SetSlidingExpiration(TimeSpan.FromSeconds(30));
                       entry.SetSize(1000);
                       return new PageReport(reportFile);
               settings.UseCompression = true;
    Hope it helps.
