Designer fail in Trialversion AR 14 in VS2019 / codeb. SectionReports
Posted by: daniel.boss on 17 February 2020, 4:09 am EST
    Posted 17 February 2020, 4:09 am EST - Updated 30 September 2022, 5:20 pm EST
    Hello
    I’m current on testing(Trial) your ActiveReports 14 on an Win 8.1 machine und running with VS 2019 16.4.X
    On our current product we using AR 6 with codebased reports, and it works fine.
    With the new Version i have massive Troubles, and i don’t know if its comming from the visualstudio 19 oder AR 14.
    The Problem is, that the VS19 Designer not work correctly.
    Step 1 : Start VS with an new (empty) AR14 Project and code-based Report.
    Step 2 : try to open the Report brings me this message :
    Step 3 : Close VS19 and reopen the Project
    Now the Report showing up correct.
    My Problem is, when i just Close this Report, and then restart VS19 again…
    then the error-message Shows again if i try to open the Report.
    So if i have for every work in reports, to Close VS, open it…and and and… its unusable for me.
    Do you know this Problem?
    That occours only with codebased reports!
    Greeting
    Daniel
  • Posted 17 February 2020, 8:37 am EST
    Please try the following workaround:
    Please add a reference to GrapeCity.ActiveReports.Serializer NuGet package manually after update
    Also, if the problem still occurs:
    Try to reset VS (https://docs.microsoft.com/en-us/visualstudio/ide/reference/resetsettings-devenv-exe?view=vs-2019)
    If the issue is not resolved, please let me know.
  • Posted 17 February 2020, 11:43 am EST
    Hi Mohit,
    Thank you for the tips.
    The reference-part was not working, still the same effect.
    It looks like VS19 does not load the AR14-Dll’s to show the report, if it was not opened at startup.
    I will now try to reset setting and/or reinstall VS2019.
    Daniel
  • Posted 18 February 2020, 8:14 am EST
    Hello Daniel,
    It is a known issue with AR14. You can try to reset the setting. Or you can try with latest hotfix:
    http://cdn.grapecity.com/ActiveReports/AR14/Hotfixes/ActiveReports-v14.0.19313.msi
    Also, our developer team are working on the new hotfix and will inform you once I get any information from them.
  • Posted 18 February 2020, 9:52 am EST
    Hello Mohit
    With the Hotfix runs AR14 now fine, thank you!
    Greetings
    Daniel
