Doc of namespace changes v12 to v13?
Posted by: law on 19 June 2019, 1:15 pm EST
    Posted 19 June 2019, 1:15 pm EST
    I’m migrating a bunch of reports from AR version 12 to v13 and I’m getting a lot of "The type or namespace name ‘xxx’ does not exist in the namespace ‘yyy’ errors with respect to AR object properties. The two most common are GrapeCity.ActiveReports.Document.Section.TextAlignment and GrapeCity.ActiveReports.Document.Section.VerticalTextAlignment.
    Is there a doc somewhere that tells what changed from 12 to 13 so I can fix these?
    Thanks!
    Eric Law
  • Posted 20 June 2019, 5:45 am EST
    You can use the following enum in present in “GrapeCity.ActiveReports.Core.Rendering” dll
    GrapeCity.ActiveReports.Drawing.TextAlignment
    GrapeCity.ActiveReports.Drawing.VerticalTextAlignment
    GrapeCity.ActiveReports.Drawing.WrapMode
    instead of
    GrapeCity.ActiveReports.Document.Section.WordWrap
    You can also refer to the following breaking change:
    https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#BreakingChanges.html
    If you still face any problem, please feel free to revert back.
