Posted 31 May 2023, 12:04 pm EST
How would you configure datasets and display for dynamic data?
For instance a series of objects with their own sets of data. See Json below:
Example 1
"steps": {
"1":{
"Operation": "Upset",
"FE Weight": 11286.736,
"Upset From": 25.049892,
"Donut Height": 24,
"Ratio": 0.5566643,
"Upset OD": 45.299927,
"Met Red": 1.0437455,
"Cert Red": 1.0437455
"2":{
"Operation": "Snap",
"FE Weight": 10957.997,
"Snap Size": 10,
"Snap Weight": 250,
"Snap Height": 24,
"Met Red": 1,
"Cert Red": 1
"3":{
"Operation": "Open",
"FE Weight": 107707.997,
"Open From": 10,
"Open To": 15,
"Met Red": 1.1134975,
"Cert Red": 1.1134975
"4":{
"Operation": "Final Draw",
"FE Weight": 10707.997,
"Start Length": 24,
"Finish Length": 35,
"Met Red": 1.4583334,
"Cert Red": 1.4583334
Example 2
"steps": {
"1":{
"Donut Height": 24,
"Ratio": 0.5566643,
"2":{
"Snap Size": 10,
"Snap Weight": 250,
"Snap Height": 24,
"Met Red": 1,
"Cert Red": 1
"3":{
"Open From": 10,
"Open To": 15,
"4":{
"Operation": "Draw",
"Start Length": 24,
"5":{
"Open From": 10,
"Open To": 15,
"6":{
"Start Length": 24,
Basically I want to export results from a calculator application I made and generate a report. Depending on the calculation will depend on the sequence and number or “steps” in the object. I am open to restructuring the JSON to meet what would work best.
