Encrypting a direct database connection string
Posted by: bill on 24 March 2020, 9:20 am EST
  • Posted 24 March 2020, 9:20 am EST
    I am concerned about having the connection string properties in RDLX files with customers using the End User Report Designer. I looked at this article:
    https://www.grapecity.com/forums/ar-dev/prevent-access-to-oracle-d
    It is a good way for hiding the connection string in the report designer, but it is still stored in the RDLX file. Is there a way to store it encrypted in the RDLX file?
    We do not use a Report Server so the Shared Data Sources are not an option for us. We are using AR12, but could upgrade to AR14 if needed.
  • Posted 25 March 2020, 1:00 am EST
    Hello Bill,
    You can use the local shared datasource to achieve your requirements. Please refer to the following link:
    https://help.grapecity.com/activereports/webhelp/AR13/webframe.html#WorkwithLocalSharedDataSource.html
    You can refer to the “Nwind.rdsx” file at the following location to know more about how to create local shared datasource.
    ~\Documents\GrapeCity Samples\ActiveReports 12\Data
  • Posted 25 March 2020, 7:45 am EST
    Thanks, I believe this will meet our needs
