Error when printing pagedocument AR 15.1.7
Posted by: mpoelen on 5 April 2022, 6:55 am EST
    Posted 5 April 2022, 6:55 am EST
    I’m new in active reports and i am trying to print a report in a asp.net web api in .net 5. I have managed to render a report and get back as a pdf when doing a get request. When i want to print te same report i get the following exception.
    “message”: “Could not load file or assembly ‘System.Resources.Extensions, Version=4.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51’. The system cannot find the file specified.”,
    “type”: “System.IO.FileNotFoundException”,
    Don’t know if it has anything to doe with it but:
    When in debug mode i see that the pagedocument.IsEmpty throws an exception of type InvalidOperationException.
    Here is the used code
        /// <summary>
        /// Get all report categories.
        /// </summary>
        ///// <param name="id"></param>
        ///// <param name="queryParameterString"></param>
        /// <param name="ct"></param>
        /// <response code="200">Ok</response>
        /// <response code="400">Bad Request</response>
        /// <response code="401">Unauthorized</response>
        /// <response code="403">Forbidden</response>
        /// <response code="404">Not Found</response>
        /// <response code="500">Internal Server Error</response>
        /// <returns></returns>
        [HttpGet("print-custom")]
        //[Produces(@"application/pdf")]
        [ProducesResponseType(typeof(Stream), 200)]
        [ProducesResponseType(typeof(ValidationProblemDetails), 400)]
        [ProducesResponseType(typeof(ProblemDetails), 401)]
        [ProducesResponseType(typeof(ProblemDetails), 403)]
        [ProducesResponseType(typeof(ProblemDetails), 404)]
        [ProducesResponseType(typeof(ProblemDetails), 405)]
        [ProducesResponseType(typeof(ProblemDetails), 500)]
        public async Task<bool> PrintLabel(/*int id, string queryParameterString,*/ CancellationToken ct)
          var pageReport = new PageReport();
          var xmlString = await _labelService.GetLabelScript(27, ct);
          var connectionString = _configuration.GetConnectionString("ConnectionString");
          pageReport.Run();
          var pageDocument = pageReport.GeneratePageDocument(
              xmlString, "1", false, connectionString
          pageDocument.SetParameterValues(null);
          var printerSettings = new GrapeCity.ActiveReports.PrinterSettings(pageReport.Report)
            ShowPrintDialog = false,
            ShowPrintProgressDialog = false,
            UsePrintingThread = false,
            UseStandardDialog = false,
            UseXpDialog = false
          printerSettings.Printer.Landscape = true;
          printerSettings.Printer.PrinterName = "Microsoft Print to PDF";
          printerSettings.Printer.PrinterSettings.Copies = 1;
          //var r = pageDocument.IsEmpty;
          pageDocument.Print(printerSettings);
          return true;
          //// Code below renders the pagedocument and this works
          //Provide settings for your rendering output.
          //var pdfSetting = new GrapeCity.ActiveReports.Export.Pdf.Page.Settings();
          // // Set the rendering extension and render the report.
          // var pdfRenderingExtension = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
          // var outputProvider = new GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider();
          // pageDocument.Render(pdfRenderingExtension, outputProvider, pdfSetting);
          // return outputProvider.GetPrimaryStream().OpenStream();
    Extension methods used:
      internal static class GrapeCityPageReportExtensions
        internal static PageDocument GeneratePageDocument(
          this PageReport pageReport,
          string labelScript,
          string queryParameterValue,
          bool fixPageDimUndefined,
          string connectionString)
          pageReport
            .LoadString(labelScript)
            .SetQueryParameterValue(queryParameterValue)
            .DdrToAr(fixPageDimUndefined)
            .SetConnectString(connectionString);
          pageReport.Run();
          return new PageDocument(pageReport);
        internal static PageReport LoadString(this PageReport pageReport, string labelScript)
          if (pageReport == null || string.IsNullOrEmpty(labelScript))
            return pageReport;
          using TextReader tr = new StringReader(labelScript);
          pageReport.Load(tr);
          return pageReport;
        internal static PageReport SetQueryParameterValue(this PageReport pageReport, string queryParameterValue)
          if (pageReport == null || string.IsNullOrEmpty(queryParameterValue))
            return pageReport;
          var dataSet = pageReport.Report?.DataSets?.FirstOrDefault();
          var queryParameter = dataSet?.Query?.QueryParameters.FirstOrDefault();
          if (queryParameter != null)
            queryParameter.Value = queryParameterValue;
          return pageReport;
        internal static PageReport DdrToAr(this PageReport pageReport, bool fixPageDimUndefined)
          if (pageReport == null || !fixPageDimUndefined)
            return pageReport;
          if (pageReport.Report.PageHeight.IsUndefined)
            pageReport.Report.PageHeight = pageReport.Report.Body.Height;
          if (pageReport.Report.PageWidth.IsUndefined)
            pageReport.Report.PageWidth = pageReport.Report.Width;
          return pageReport;
        internal static PageReport SetConnectString(this PageReport pageReport, string connectionString)
          if (pageReport == null || string.IsNullOrEmpty(connectionString))
            return pageReport;
          var dataSource = pageReport.Report?.DataSources?.FirstOrDefault();
          if (dataSource != null)
            dataSource.ConnectionProperties.ConnectString = connectionString;
          return pageReport;
  • Posted 5 April 2022, 10:33 am EST
    The problem is already solved, an Package reference was missing.
  • Posted 6 April 2022, 3:37 am EST
    Hi Mark,
    I am glad you were able to resolve your issue. Thanks for sharing the solution with us. It will help others who are doing something similar.
  • Posted 28 February 2023, 5:03 pm EST
    I am having the same issue - what package did you need to add?
  • Posted 1 March 2023, 11:45 pm EST
    Hi Mike,
    This seems to be a generic issue. As per the error message the package “System.Resources.Extension” is not found. I would suggest you to try adding this package to your project and refer to the following post on the StackOverFlow Forum page:
    https://stackoverflow.com/questions/64298051/cant-load-system-resources-extensions-in-net-framework
    If the issue persists then please share a sample application reproducing this issue so we can reproduce this issue at our end and get back to you accordingly.
    Akshay
