Posted 1 February 2024, 9:25 am EST
Hello, i’m trying to render a report to Excel using ExcelRenderingExtension using pagination to separate the data i have into groups using pagebreak in the RDL to separate sheets for every grouping, the problem i have is that using this type of pagination i’m limited to the value of PageHeight property which it’s max value is 160in which causes the data to separate to sheets every ~800 rows. Is there any way to achieve unlimited rows per sheet/group using PageReport render? If not is there any render/export class that can achieve what i need?
I’m attaching the RDL that i’m using. Thank you.RDL.zip
