Export a embedded rdlx report whitout show it
Posted by: josemiguel.alcalde on 13 November 2020, 10:45 am EST
    Posted 13 November 2020, 10:45 am EST
    Hello
    I’m loading a embedded report in a form, and it works fine, when it’s shown in a form, but now, I also need to export it from a background proccess, whitout showing the form.
    I have tried to export from the viewer, but if I don’t show the form, the pdf is empty. If I show it, the pdf is fine. How can I do this?
    Thank in advance
    This is how I load de the report
        Public Sub LoadReport(reporte As String, ensamblado As String, parametro As String(,))
            Dim asm As Assembly
            asm = Assembly.LoadFrom(ensamblado)
            Dim stream As Stream = asm.GetManifestResourceStream(reporte)
            UcVisualizadorReportes1.LoadDocument(stream, GrapeCity.Viewer.Common.DocumentFormat.Rdlx)
            Dim parametros As GrapeCity.Viewer.Common.IParameter
            Dim pc As IList(Of GrapeCity.Viewer.Common.IParameter) = New List(Of GrapeCity.Viewer.Common.IParameter)()
            For i As Integer = 0 To parametro.GetLength(0) - 1
                Dim param As GrapeCity.ActiveReports.Viewer.Win.ReportParameter = New GrapeCity.ActiveReports.Viewer.Win.ReportParameter(parametro(i, 0), parametro(i, 1))
                pc.Insert(i, param)
            Next i
            UcVisualizadorReportes1.SetParametersValues(pc)
        End Sub
    And this is how I export the report to pdf when the form is shown
    Dim p As New GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport
                    p.NeverEmbedFonts = ""
                    p.ImageQuality = GrapeCity.ActiveReports.Export.Pdf.Section.ImageQuality.Highest
                    Me.Export(p, New FileInfo(dialogSave.FileName))
                    MessageBox.Show(dialogSave.FileName + " " + My.Resources.ExportCompleteString)
  • Posted 17 November 2020, 4:39 am EST
    Can you try with the following code:
    Dim rptPath As New IO.FileInfo("..\..\PageReport1.rdlx")
    Dim pageReport As New GrapeCity.ActiveReports.PageReport(rptPath)
    ' Create an output directory.
    Dim outputDirectory As New System.IO.DirectoryInfo("C:\MyPDF")
    outputDirectory.Create()
    ' Provide settings for your rendering output.
    Dim pdfSetting As New GrapeCity.ActiveReports.Export.Pdf.Page.Settings()
    ' Set the rendering extension and render the report.
    Dim pdfRenderingExtension As New GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension()
    Dim outputProvider As New GrapeCity.ActiveReports.Rendering.IO.FileStreamProvider(outputDirectory, System.IO.Path.GetFileNameWithoutExtension(outputDirectory.Name))
    ' Overwrite output file if it already exists
    outputProvider.OverwriteOutputFile = True
    pageReport.Document.Render(pdfRenderingExtension, outputProvider, pdfSetting)
    Also, you can use the TextReader to load the report from stream in PageReport. Please refer to following code:
    MemoryStream ms = new MemoryStream();
                ms.Position = 0;
                TextReader tr = new StreamReader(ms);
                PageReport rpt = new PageReport(tr)
