Export PDF as MemoryStream
Posted by: hanson.h.fong on 4 October 2022, 10:35 pm EST
    Posted 4 October 2022, 10:35 pm EST
    I am using trial license to try the features, and I have encountered an issue when I tried to implement the Azure Functions with exporting PDF to Blob storage.
    pageReport.Document.Render(pdfRenderingExtension, outputProvider, pdfSetting);
    When the above code executed, there is an exception message.
    “This application will be terminated because it was built without a license for PageReport.”
    Here is my full code below:-
    var outputProvider = new GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider();
    var pageReport = new GrapeCity.ActiveReports.PageReport(new FileInfo(localFilePath));
    var pdfSetting = new GrapeCity.ActiveReports.Export.Pdf.Page.Settings();
    var pdfRenderingExtension = new GrapeCity.ActiveReports.Export.Pdf.Page.PdfRenderingExtension();
    using (var fileStream = (MemoryStream)outputProvider.GetPrimaryStream().OpenStream())
    	await blockBlob.UploadFromStreamAsync(fileStream);
            responseMessage = blockBlob.Uri.ToString();
  • Posted 6 October 2022, 6:31 am EST - Updated 6 October 2022, 6:39 am EST
    In order to license a project which utilizes the azure function, please try creating a gclicx file, and adding the same in the given project as an ‘Embedded Resource’. You may use the below-specified command to generate the same:
    gclm.exe "5e0b5f44-1a6b-4aff-a007-17b9224bca83" -lc .\.gclicx Microsoft.Azure.WebJobs.Script.WebHost.[assembly name].dll
    For more information on the same, please refer to the below link:
    https://www.grapecity.com/activereportsnet/docs/latest/online/licensing-compiled-code.html
    Also, Please add the following line in the csproj file to disable the generating the license:
    <DisableGclm>True</DisableGclm>
    Dushyant Sharma
