Export to PDF Exception
Posted by: ilia on 27 April 2018, 1:48 am EST
    Posted 27 April 2018, 1:48 am EST - Updated 30 September 2022, 6:20 pm EST
    I use the last version of AR 12.1 for export SectionReport to pdf. I don’t use Chinese characters. Why Export function throws exception ‘Font ‘PMingLiU’ cannot be found.’?
  • Posted 27 April 2018, 3:31 am EST
    Could you please share the report to replicate the issue at my end. Also, you can try the following line of code to avoid the issue.
    PdfExport1.NeverEmbedFonts="PMingLiU"
    Hope it helps.
  • Posted 27 April 2018, 8:22 am EST - Updated 30 September 2022, 6:20 pm EST
    PdfExport1.NeverEmbedFonts=“PMingLiU” does not help.
    How many fonts opens/searches the export function?
    My test report contains only one TextBox with font Arial, charset 177.
  • Posted 28 April 2018, 3:47 am EST
    Example attached.
    See
    Exception thrown: ‘System.ArgumentException’ in System.Drawing.dll
    in the Output (Debug) View SectionReportApplication2.zip
  • Posted 30 April 2018, 2:43 am EST
    I am not able to reproduce the error with your attached sample “SectionReportApplication2”. Could you please check the sample again with AR12 SP1.
  • Posted 30 April 2018, 3:52 am EST - Updated 30 September 2022, 6:20 pm EST
    I use the last version of AR 12.1 (SP1) for export SectionReport to pdf.
    Could you please check the sample again with System.ArgumentException in the Exception Settings.
  • Posted 30 April 2018, 5:38 am EST
    Sorry to mention that issue is still not reproducible at my end. Please refer the attached video. However, you can try with our latest hotfix of AR12 SP1. Please download the installer at the following link:
    http://cdn.grapecity.com/ActiveReports/ar12/hotfixes/ActiveReports-v12.1.13124.0.msi
    vid_SecitionPDf.zip
  • Posted 30 April 2018, 11:48 pm EST - Updated 30 September 2022, 6:20 pm EST
    I installed 13124 Hotfix. It still occurs.
    Could you please share your 444.pdf.
  • Posted 1 May 2018, 1:34 am EST
    Please refer the attachment for the required document. Could you please try on another system and see if issue replicates on another system also.
    444.zip
