Export to XLSX with formulas not correct
Posted by: darin on 10 April 2019, 7:37 am EST
  • Posted 10 April 2019, 7:37 am EST
    AR11
    See attached RPX, PDF, and XLSX. The RPX creates the PDF fine, notice the far right column (turns) calculates correctly throughout the report. But, if you look at the XLSX it is not - most are zero when they should not be. Not sure how the PDF and XLSX versions could be different.
    Any ideas?PDFXLScalculation.zip
  • Posted 10 April 2019, 7:56 am EST
    Darin,
    Could you please try this in “Format” event of GroupFooter/ReportFooter instead of “BeforePrint” event.
    Also, if possible could you please share the sample DB so that I can run the report at my end.
  • Posted 10 April 2019, 9:51 am EST
    Putting it in the Format instead of before print made no change to the XLS report.
  • Posted 12 April 2019, 5:00 am EST
    Darin,
    I am not able to reproduce with my sample report and database. Could you please provide the sample Db of your report so that I can replicate the issue at my end?
