Posted 6 April 2018, 12:42 am EST
Failed to add the custom paper size to the printer ARCustomForm
When printing to a shared Zebra printer from another PC
Posted by: kim on 6 April 2018, 12:42 am EST
Posted 9 April 2018, 2:06 pm EST
Hi Kim,
Can you please mention the type of report you’re using (Section/Page/RDL) and what is the exact version of ActiveReports that you’re using? Also, is ARCustomForm the name of your Printer?
Would it be possible for you to share you application or the code you’re using to add the custom paper size?
Posted 20 April 2023, 5:12 am EST
To resolve this issue, change the default paper size of your printer: Click Start, point to Settings, and the click Printers. Right-click the appropriate printer, and then click Properties. Click the Paper tab, and then click the paper size you want to use in the Paper Size box.
