Fixed column in section report
Posted by: joakimsinbox on 26 May 2021, 2:33 pm EST
  • Posted 26 May 2021, 2:33 pm EST - Updated 30 September 2022, 4:41 pm EST
    Is it possible to create a “label-column” that is not repeated in every column in a multi-column layout? I’m using a section report and would like to show four columns in a AcrossDown layout with an explanatory column of labels on the left.
  • Posted 27 May 2021, 1:36 am EST
    You can create a columnar report without explanatory column. After that, you can use the created report as sub report in the main report where you can add the explanatory data.
    Hope it helps.
  • Posted 29 May 2021, 1:01 pm EST
    Thanks!
    So is there not any other way to do this?
    I can not use subreports since I don’t have direct access to the database.
  • Posted 31 May 2021, 12:22 am EST
    No, there is no other way. You can pass the data from main report to sub report to achieve your requirement.
