Posted 14 September 2017, 7:18 pm EST
[activereports_archive]
@Ruchir.Agarwal@grapecity.com said:
Thank you for sharing more information.
However, we still could not reproduce the issue at our end. Please refer to the attached video.
What Adobe version are you using, we have “2017.009.20044” Abode Acrobat Reader DC at our end.
Also, were you able to replicate the issue even when you run the Visual Studio application and click on “Export to PDF” button (after viewing the report by clicking “View” button) in browser.
I have uploaded the sample application once again for you to test:
https://www.dropbox.com/s/z6adka0p6bst70p/FormattedText_BoldIssue.zip?dl=0
Thanks & Regards
Ruchir Agarwal
My Adobe Reader is current (17.009.20044) as is my Foxit Reader. The reader has no bearing on this issue. If I can see bold font with print to PDF but not export, then the viewer can obviously see bold font, since it shows it on one.
Answer me this one question…
If you open the FormattedText.rdlx from the example application you sent me in ActiveReports 11 Viewer, and click File/Export on the top menu, choose PDF as the format and save the file, does the file show the bold font when you view it in Acrobat Reader? does it print bold font when you print the exported PDF?
If the answer is no, then you are seeing what I’m seeing and there is a problem Exporting PDF files from the Viewer app. I would assume the library behind this function is the same as what I’d be calling from the code I write, since I’m observing the same issue there.
[/activereports_archive]
