Posted 30 June 2023, 11:58 am EST
We are using AR15 in a series of DLLs that are consumed by a web application. I’ve been able to get the licensing to work through the use of a .gclicx file generated for one of those DLLs (as a test run), however, it appears that all of the DLLs are working, even though I generate the .gclicx file for only one of them. Can you please explain why this is occurring, and whether or not we should add the .gclicx file for each of our DLLs which reference AR15 packages.
Thank you, Patrick
