@grapecity/ar-viewer npm package issue
Posted by: ricardo.pereira on 2 September 2020, 4:30 am EST
  • Posted 2 September 2020, 4:30 am EST
    I would like to point out some issues I’ve found while using @grapecity/ar-viewer npm package:
    • The jsViewer.min.css file even though it says “min” it isn’t minified. That in my opinion is a bit misleading. I don’t know if this was made by design but I guess that the contents of this file should be minified.
    • Another issue is the fact that in that same file there’s a css block with the following code:
    html,
    body {
      width: 100%;
      height: 100%;
      margin: 0;
      padding: 0; }
    This in my opinion is incorrect because if someone tries to embed this JSViewer into their web site the body style will potentially be overridden.
    In our case padding 0 messed up some of our other component styles. We removed that block of code then everything went back to normal.
    This is not a criticism in any way because I think you did a really good job in general. Hope you appreciate the feedback.
    Ricardo Pereira
  • Posted 2 September 2020, 1:46 pm EST
    Thanks for the feedback.
    I have forwarded this to our development team(AR-25033) and will inform you once I get any information from them.
