Hiding the file button on ar-designer
Posted by: ewan.johnstone on 22 May 2023, 6:54 am EST
    Posted 22 May 2023, 6:54 am EST
    We are using ar-designer v17.
    I am wanting to hide the file button from the designer UI as we do not use it.
    The only way I have found to hide it is to set appBar.visible = false in the designer settings but this hides the preview button which we do use. Is there a setting for hiding just the file button that for some reason isn’t documented in the API? Or perhaps another way of hiding this element manually?
  • Posted 23 May 2023, 11:33 pm EST
    Hi Ewan,
    Unfortunately, there’s no direct way of hiding the file button in the Web Designer. However, you can use the DOM to modify, access, and hide the file button through javascript.
    Please find attached a sample implementing the same for your reference.
    Anand
    WebDesigner_MVC.zip
  • Posted 20 July 2023, 7:58 am EST
    Actually I found the following setting did the trick:
    documents: {
    fileView: { visible: false },
  • Posted 21 July 2023, 12:10 am EST
    Hi Ewan,
    Thanks for sharing the resolution with us, it may be helpful for others facing similar issues.
    Anand
