Posted 14 September 2017, 7:16 pm EST
[activereports_archive]I have an active report 10 section report (code based), I want to know if is possible to bold just a word of a text and how?
Thanks![/activereports_archive]
Posted by: npsimplea on 14 September 2017, 7:16 pm EST
[activereports_archive]Hi,
Thanks for asking.
This feature is available in RichTextBox control.
To specify bold text programmatically use the following statement:
richTextBox1.Html = “Bold text”;
you also can append new lines of text using the following statement:
richTextBox1.Html+= “normal text”;
or paste rich text into this control manually.
Check the following article on various ways of formatting html text:
http://www.w3schools.com/html/html_formatting.asp
Drop a line if I can do anything else for you.
Tim
[activereports_archive]It worked, thanks![/activereports_archive]
[activereports_archive]Is it not possible to bold a word using a textbox?[/activereports_archive]
[activereports_archive]Hi Ivan,
In a textbox control you can only bold out the whole text, since there is no support of html tags for formating like in richtextbox control.
regards
Tim[/activereports_archive]
Posted 17 April 2020, 12:35 am EST
