How to build Linux Docker Image in AZ Devops for ActiveReport Pipeline License
Posted by: hanson.h.fong on 10 February 2023, 9:01 pm EST
    Posted 10 February 2023, 9:01 pm EST
    I can successfully build the docker image through Azure DevOps CI/CD pipeline with Windows (Agent Specification).
    Is it possible to build by Linux agent? Since I needed to deploy into AKS Linux Cluster. If yes, can anyone provide me the instructions for this?
    Please advise.
  • Posted 13 February 2023, 8:28 am EST
    Hi Hanson,
    You may build your project in a Linux Container only if it is of the type ASP.NET Core. As this is a generic question you may follow the steps provided here to build/run your project in a Linux Container: https://learn.microsoft.com/en-us/aspnet/core/host-and-deploy/docker/building-net-docker-images?view=aspnetcore-7.0
    Also, to build your ActiveReports application on Azure Pipelines you’ll need to license your Pipeline following the steps provided along with your ActiveReports Pipeline License which are:
    To activate your pipeline serial key on the build server follow these steps:
    • Install the GrapeCity License Manager tool (gclm) in the pipeline.
    • If ActiveReports is installed, then the gclm tool is already installed at (C:\ProgramData\GrapeCity\gclm)
    • If ActiveReports is not installed, you may download the gclm deployment tool:
    • Copy the Local Activation Package file (that you got along with your Pipeline license) to the gclm install location.
      • Windows: C:\ProgramData\GrapeCity\gclm
      • Linux/MacOS: ~/.local/share/GrapeCity/gclm
    • Before the build, call the gclm tool to activate the license using your serial key and provided password.
      • Windows: C:\ProgramData\GrapeCity\gclm\gclm.exe “product-id” -a “key” “password”
      • Linux/MacOS: gclm “product-id” -a “key” “password”
    Note: You may also perform the activation (step 3) using the GrapeCity License Manager GUI if command line interface is not required. See Activating a Serial Key and follow the steps activating your pipeline key for ComponentOne Studio Enterprise. It will prompt you to enter the password separately.
    Anand
