How to Create a Horizontal Report?
Posted by: ricagmcr on 14 September 2017, 7:16 pm EST
  • Posted 14 September 2017, 7:16 pm EST
    [activereports_archive]In AR-11 you can create a report that is filled horizontally ?
    I do not mean that the page orientation is horizontal, what I want is that the detail containing ‘ N ‘ columns, where ‘N’ is the number of records in a table .
    I clarify that in the number of columns will never exceed 6, but if I need to dynamically fill columns based on the number of records in my query / data source (1 to 6).
    So I have no problem with the width of the page, because the columns will never exceed 6.[/activereports_archive]
    [activereports_archive]Hello,
    Your requirement can be fulfilled by using a Columnar Report that runs AcrossDown. ActiveReport is designed to grow vertically and the only built in functionality that would cause the reports to render the next Detail Section horizontally would be if the reports were set up in a columnar format.
    For more information regarding the same, please refer to the following documentation link:
    http://arhelp.grapecity.com/webhelp/AR11/index.html#arWLKColumnarReports.html
    Let me know if this does not meet your requirement.
    Ruchir Agarwal[/activereports_archive]
    On further research I found Tablix control would be more suited for your requirements.
    For more information regarding this, please refer to the following documentation link:
    http://arhelp.grapecity.com/webhelp/AR11/index.html#Tablix.html
    http://arhelp.grapecity.com/webhelp/AR11/index.html#TablixReports.html
    http://arhelp.grapecity.com/webhelp/AR11/index.html#ElementsofTablixDataRegion.html
    http://arhelp.grapecity.com/webhelp/AR11/index.html#ColumnarReportsRDL.html
    I am also attaching sample application demonstrating both the approaches.
    *Note: Please rename the file to extension “.zip” after downloading.
    Let me know if you need anything else.
    Thanks & Regards
    [activereports_archive]Hi,
    It seems the file could not be attached, hence I have uploaded the same to DropBox.
    Please download the application using the following link:
    https://www.dropbox.com/s/gky2qg5ymn1volg/prj_GrowDataHorizontallyAR.zip?dl=0
    Thanks & Regards
  • Posted 15 March 2018, 7:06 am EST
    Can I get example of page report that the data grows horizontally, i.e Across, then Down (The Detail bands are printed horizontally, then vertically (in rows).
