How to declare a global connection string for AR
Posted by: prakash1234 on 14 September 2017, 7:03 pm EST
    Posted 14 September 2017, 7:03 pm EST
    [activereports_archive]Hi,
    Currently I’m passing connection string to every RPX file, but I want to make it global, so that i can create a key in web.config file in my project and pass it to all RPX files.
    Is there any way to do so.
    Thank You!!
    Prakash[/activereports_archive]
  • Posted 14 September 2017, 7:03 pm EST
    [activereports_archive]Hi Prakash,
    Yes, you can create a global key in element of a web.config file to define the connection string and further use it wherever required using “System.Configuration.ConfigurationManager.AppSettings”.
    In web.config file, you can make the appSetting entry to hold the connection string:
     <appSettings>
        <add key="ConnectionString" value="Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Users\Windows8.1\Documents\GrapeCity Samples\ActiveReports 10\Data\Reels.mdb;Persist Security Info=False" />
      </appSettings>
    Further, you can access it using 'System.Configuration.ConfigurationManager’class and define the datasource of the report:
    [csharp] protected void Button1_Click(object sender, EventArgs e)
    SectionReport rpt1 = new SectionReport();
    System.Xml.XmlTextReader xtr = new System.Xml.XmlTextReader(Server.MapPath(“~/SectionReport1.rpx”));
    rpt1.LoadLayout(xtr);
    xtr.Close();
            string connString = ConfigurationManager.AppSettings["ConnectionString"];
            conn = new System.Data.OleDb.OleDbConnection(connString);
            System.Data.OleDb.OleDbCommand cmd = new System.Data.OleDb.OleDbCommand("Select * from Customer", conn);
            conn.Open();
            reader = cmd.ExecuteReader();
            rpt1.DataSource = reader;
            rpt1.Run();
            WebViewer1.Report = rpt1;
        }[/csharp]
    Please refer to the attach sample implementing the same.
    Let me know if you faces any confusion.
    Shubham Srivastava[/activereports_archive]
    2015/11/AR_GlobalConnectionString.zip
  • Posted 6 June 2020, 1:56 am EST
    How do I put my connection string in my web config in AR 14? How do I access it from code? In the report designer, do I remove the connection string?
  • Posted 8 June 2020, 11:55 am EST
    Your query has been replied here:
    https://supportone.componentone.com/casedetail/439777
