Posted 2 January 2018, 5:42 pm EST
We’re currently evaluating Active Reports on a 30-day trial. We’ve been successful in passing a multivalued integer parameter to a stored procedure by defining the parameter in the stored proc as NVARCHAR(4000) and then using String_Split to create a table of the integer values.
However when we try to define a multi-valued string parameter to a proc where the parameter is defined as an NVARCHAR(4000) Active Reports tells us it is an invalid parameter.
I’m unable to find anything in the documentation that deals with passing multi-valued parameters to stored procs.
Can you tell me how this can be done?
Stan
