How to prevent the HTML renderer from converting email text to Images?
Posted by: andrew.williams on 18 August 2025, 6:48 pm EST
  • Posted 18 August 2025, 6:48 pm EST
    I am attempting to use a PageReport to render HTML that will eventually be used in emails like a password reset or auth code. However, no matter what I change in the export settings, all of the text content is converted to SVGs and images. This makes copying text from the email impossible. How can I modify this code so that raw html is returned? I am using Active Reports 17.3.0 and C#.
    [code]var htmlRenderingExtension = new GrapeCity.ActiveReports.Export.Html.Page.HtmlRenderingExtension();
    var htmlOutputProvider = new GrapeCity.ActiveReports.Rendering.IO.MemoryStreamProvider();
    var htmlPageSettings = new GrapeCity.ActiveReports.Export.Html.Page.Settings
    EmbedImages = true,
    Fragment = true,
    StyleStream = false,
    MhtOutput = false,
    Mode = GrapeCity.ActiveReports.Core.Export.Html.Page.RenderMode.Galley,
    RenderingEngine = GrapeCity.ActiveReports.Core.Export.Html.Page.RenderingEngine.Html
    pageDocument.Render(htmlRenderingExtension, htmlOutputProvider, htmlPageSettings);
    var text = string.Empty;
    using (var documentStream = (MemoryStream)htmlOutputProvider.GetPrimaryStream().OpenStream())
    using (var reader = new StreamReader(documentStream, Encoding.UTF8, true, 1024, leaveOpen: false))
    text = reader.ReadToEnd();
    returnArray = Encoding.Default.GetBytes(text);
    }[/code]
  • Posted 19 August 2025, 1:26 am EST
    Hi Andrew,
    Please try to change the rendering engine from HTML to Mixed.
    I hope this fixes this issue:
    RenderingEngine = GrapeCity.ActiveReports.Core.Export.Html.Page.RenderingEngine.Mixed
    If the issue persists, please share a sample report file reproducing this issue. So we can look into this issue and get back to you accordingly.
  • Posted 19 August 2025, 12:59 pm EST
    Unfortunately that only made it worse, none of the content appears in the emails after setting the rendering engine to mixed. I’ve attached a simplified report that exhibits the issue. Please let me know if you need any more details.
    Test Email.zip
  • Posted 20 August 2025, 1:31 am EST
    Hi Andrew,
    I tested again at my end with your report and was able to reproduce this behavior.
    It seems that when using a Table Control, the Formatted Text Control is rendered as an SVG file.
    As a workaround, I would suggest not using a Table for formatting the context if possible. Also, when exporting to HTML, make sure the following export properties are set:
    RenderingEngine = Mixed
    EmbededImages = True
    I have attached a sample report with your HTML and another sample HTML, which does not use the Table control.
    Akshay
    Test.zip
