How to print a Code 128 that starts and end with a different char-set
Posted by: ylarente on 13 February 2020, 3:02 pm EST
  • Posted 13 February 2020, 3:02 pm EST
    How can we print a Code 128 Barcode which starts with the char-set B and ends with char-set C using ActiveReports 13.
    E.g. ABCD1234567890 where ABCD is in char-set B and 1234567890 in char-set C
    I found a simillar post but I don’t know what style of barcode to use for this and how to enter the code to switch from one char-set to another. If you could give me an example of a string that would do the trick and the style of barcode to use, it would help a lot.
    https://www.grapecity.com/forums/ar2/how-to-define-character-se
    Thank you
  • Posted 14 February 2020, 2:18 am EST
    Unfortunately, it is not supported as of now. However, it has already been forwarded to the concerned team as an enhancement request(132584).
