Image Not Showing Up in Report
Posted by: dellis on 1 December 2020, 7:53 pm EST
    Posted 1 December 2020, 7:53 pm EST - Updated 30 September 2022, 4:53 pm EST
    I made a rdlx report with as an external image, however, when I run the report via the JSViewer, the image is not found. The image is in the correct path. I also tried setting as an embedded image, and I’m have the same issue.
    When I check the console log, I’m getting a 404 for a PNG file, I assume this is my image.
  • Posted 2 December 2020, 3:30 am EST
    Will you try after replacing the handler in the Web.config with the following handler:
    <add name="nostaticfile" path="api/reporting/*" verb="GET" type="System.Web.Handlers.TransferRequestHandler" preCondition="integratedMode,runtimeVersionv4.0" />
    </handlers>
  • Posted 2 December 2020, 12:47 pm EST
    Thanks much Mohit, this worked!
  • Posted 2 December 2020, 12:49 pm EST
    I did the following however, but it looks like it will work the same:
    <location path="api/reporting/view">
       <system.webServer>
         <handlers>
           <add name="nostaticfile" path="*" verb="GET" type="System.Web.Handlers.TransferRequestHandler" preCondition="integratedMode,runtimeVersionv4.0" />
         </handlers>
       </system.webServer>
     </location>
