Posted 22 March 2019, 2:10 pm EST
I ran the install for ActiveReports 13.x. How do I get them installed to the GAC
thanks
gollnick
Posted by: pgollnic on 22 March 2019, 2:10 pm EST
thanks
gollnick
Posted 25 March 2019, 1:56 am EST
In my understanding, the installer of AR13 installed the AR assemblies into the GAC itself. You don’t need to install them manually.
Hope it clarifies.
Posted 29 March 2019, 2:23 pm EST
Nope… uninstalled it completely… re-ran the msi as admin … no luck. NOT in the GAC…
So … my question again is — I ran the install for ActiveReports 13.x. How do I get them installed to the GAC
C:\Windows\Assembly Version 6 is there … version 11 is there … but NO version 13
gollnick
Posted 1 April 2019, 1:57 am EST
Active13 only supports the 4.6.2 or higher .Net framework. Hence, they do not have CLR of version 2 in the installer that’s why the assembly is not registered at “C:\Windows\Assembly”. You could find the same at following location where assembly of CL4 version 4 is registered:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL.
For more information, you can refer the following link:
https://stackoverflow.com/questions/19980650/where-is-my-gac-located/19981061
Posted 2 April 2019, 10:06 am EST
Can they be safely copied to the C:\Windows\Assembly so my references can all come for the same location??
gollnick
Posted 4 April 2019, 3:14 am EST
Gollnick,
I have escalated the issue to our development team(271342) for the detail information and will inform you once I get any reply from them.
Thank.
Posted 4 April 2019, 5:17 am EST
Could you please explain why you want to this? Are you facing any error right now?
Posted 10 April 2019, 9:19 am EST
Sorry … I was out of country.
I would like this because:
1… Ver 11.xxx did it and it was nice (between projects in VB/C# and ASNA) not to have to worry about including the dll’s in the BIN whenever I promoted (published) and sent out web site updates.
2… Just cleaner to use.
gollnick
Posted 10 April 2019, 9:26 am EST
Gollnick,
In my understanding, you will not face any issue due to this. The dll’s will include into the Bin folder after you published.
You can give a try at your end.
