Intermittent Error while Exporting PDF - V9
Posted by: sanish.shaji on 31 October 2018, 12:41 pm EST
    Posted 31 October 2018, 12:41 pm EST
    We are facing issues intermittently while starting our reporting service usually after deployment.
    Details:
    System.Collections.Generic.KeyNotFoundException
    We have noted that the issue resolves itself if we re-start the service.
    Do we need to upgrade the component ? Is there a fix available ?
    Please help.
  • Posted 31 October 2018, 12:41 pm EST
    Stack Trace:
    Stack Trace : at System.ThrowHelper.ThrowKeyNotFoundException()
    at System.Collections.Generic.Dictionary‌2.get_Item(TKey key) at #mqc.#vbl.#Ali(MemoryStream stream, IList‌1 elements)
    at DataDynamics.DDLib.PdfEngine.PsPage.#Zwd()
    at DataDynamics.DDLib.PdfEngine.PsPages.#hxd(PsPage psPage)
    at GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport.#Gsd(IFilteredPage page, Graphics graphics, #aqc outputContext, IEnumerable‌1 bookmarks, IDictionary‌2 pagesMap)
    at GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport.#7pk(SectionDocument document, Stream stream, String pageRange, Byte[]& xmpMetadata)
    at GrapeCity.ActiveReports.Export.Pdf.Section.PdfExport.Export(SectionDocument document, Stream stream, String pageRange)
  • Posted 31 October 2018, 1:20 pm EST
    Following is the first error recorded in log:
    10/31/2018 3:33:26 AM [Information] DiskCache was not properly cleaned up. ‘20181031-033326-0002.tmp’ must be deleted.
    Exception details:
    System.IO.IsolatedStorage.IsolatedStorageException: Unable to delete file.
    at System.IO.IsolatedStorage.IsolatedStorageFile.DeleteFile(String file)
    at GrapeCity.ActiveReports.Document.Section.ResourceStorage.DiskCache
    2.#bUk()    at GrapeCity.ActiveReports.Document.Section.ResourceStorage.DiskCache
    2.Dispose(Boolean disposing)
    It was followed by an IndexOutOfRangeException, ArgumentException and finally System.Collections.Generic.KeyNotFoundException which repeats until service is re-started .
  • Posted 1 November 2018, 2:49 am EST
    Hello Sanish,
    Could you please check after setting the “CacheToDisk” property of document of section report to false.
