Issue with Grapecity Active Reports 12
Posted by: anuj.rohatgi on 5 August 2018, 1:12 am EST
    Posted 5 August 2018, 1:12 am EST
    Hi All,
    we recently upgraded from Active Reports 7 to Active Reports 12 ,all rdlx were running perfectly before upgrade as soon as we upgraded to active reports 12 we are facing some issues in designer.
    Attached is rdlx for referance
    Steps to follow in Active Report 7 whenever we clicked on preview tab there was not any issue
    but whenever we are opening the same report with active report 12 we are facing issue stating
    “Parent is only allowed if grouping has exactly one group expression”Grapecity_issue.zip
  • Posted 6 August 2018, 7:38 am EST
    If you remove the “Parent Group” from the “Detail Grouping” of “tableInvoiceDetails1” then no error occurs. Please refer to the attached image. Also, I have observed the same output at our end after removing the “Parent Group” from the table.
    Could you please confirm if the above solution is appropriate for you.
  • Posted 8 August 2018, 12:01 am EST
    hi mohit,
    Can you please provide me updated rdlx .
    thanks
    Anuj
  • Posted 8 August 2018, 6:27 am EST
    Anuj!
    Please refer to the attached file for the modified report.
  • Posted 22 August 2018, 12:36 am EST - Updated 30 September 2022, 6:02 pm EST
    hi All,
    still we are unable to get the desired results after removing “Parent Group” . please have a look at following screen shots
  • Posted 22 August 2018, 12:52 am EST
    please find the database along with rdlx as attachmentDatabase.zip
  • Posted 22 August 2018, 9:31 am EST
    Hello Anuj!
    Sorry for the inconvenienced caused to you.
    I have escalated your issue to our development team and will inform you once I get any information from them.
  • Posted 30 August 2018, 7:27 am EST
    Please do the following steps to make report work in AR12
    1: Open the report
    2: Remove the “Parent Group”
    3: Recreate group(remove and create again with the same expression)
    4: Preview the report
    Hope it helps.
  • Posted 30 August 2018, 10:47 am EST
    hi mohit,
    This solution is not working on my end and would be mine pleasure if I can get updated rdlx that worked for you ??
    just an reminder if you tend to see the previous conversation that I never got an updated rdlx , so it would be gr8 that you can provide me the same i.e. an updated rdlx file along with latest changes ,so that I can pursue further
    Thanks and eagerly awaiting for the response
    Anuj
  • Posted 3 September 2018, 2:51 am EST
    Hello Anuj,
    I am discussing with the developer about your issue.
  • Posted 7 September 2018, 6:04 am EST
    Hello Anuj,
    Please refers to the modified report.
    ModfiedReport.zip
