Issue with licenses file in C# project
Posted by: nadia.micalizzi on 14 July 2020, 7:45 am EST
    Posted 14 July 2020, 7:45 am EST
    Hello, I have a C# project that uses AR to generate a report pdf called by another C# project, now I know that I should include the .licx file on both projects in the properties folder, but somethings goes wrong, cause if I try to include the same licenses file (that works for the equivalents vb net projects) I get an error at while building “LC.exe” Exited with Code -1, nothing changes if a remove licenses.licx, if I try to exclude it from my projects I get exception at run time about the building without licenses, I’m pretty stucked, what could I do ?
    P.S. I’ve also tried to download a sample in C# of a report xml from your documentation (it was with the AR8 version) so I used the tool to convert to AR14 and also there lc.exe gives me error.
  • Posted 15 July 2020, 9:40 am EST
    Hello Nadia,
    You can access the following case with Forum credential(Only you can access this link):
    https://supportone.componentone.com/home/casedetail/445485
    If you have any questions related to this, please reply to the S1 case.
