Posted 25 April 2018, 5:25 pm EST
I have a multi-tray printer that has two profiles/printers configured, each profile/printer points to a different tray. The following is how i am assigning the printer to my report.
Private Sub btnPrintDefaultTestReport_Click(sender As Object, e As EventArgs) Handles btnPrintDefaultTestReport.Click
rpt.Run()
Dim Printer As New PrinterSettings
Printer.PrinterName = cmbPrinters.SelectedItem.ToString
rpt.Document.Printer.PrinterSettings = Printer
GrapeCity.ActiveReports.PrintExtension.Print(rpt.Document, False, False)
End Sub
cmbPrinters is a combo box of installed printer’s name
I select my printer that is pointing to tray 2 in the combo box and press print
“Currently this printer is not my default printer” and it prints my section report out of Tray 1.
Now if i choose the printer that is pointed to tray 2 and make it my default printer and choose that printer from my combo box it prints to tray 2 perfectly fine.
I was wondering if anyone knew how to get a non default printer to print to tray 2?
note: i have tried to manually assign the papersource tray 2 to this report and if the printer that i choose is not the default printer then it will still print it to tray 1
Also, this issue seems to happen with orientation as well. If the printer you are using to print a section report is not the default printer than my report always prints portrait even if the actual printer setting on the printer is set to landscape.
The color/greyscale settings and scaling settings work fine whether you use the default printer or not
Tested this on Windows 7 and Windows 10
Active Reports 11 is what i am using
Visual Studio 2017 and is my IDE
