Posted 27 December 2020, 7:46 pm EST
I’m loading a report in JSViewer that has numerous sub-reports, however, when I run the report in the Designer it loads quickly. If I also run the report using Visual Studio via IIS express in my MVC application, it loads quickly. However, if I deploy my application to my production environment it loads slowly when connected to IIS10.
I’m using the exact same infrastructure in Dev as in Prod, with the exception of IIS. The difference in the load times are:
3 seconds - Dev
6-8 mins - Prod
If there anything that ActiveReports relies on within IIS that should be configured?
