Measuring the length of a string in a textbox at run time
Posted by: Administrator on 26 September 2018, 4:06 am EST
    Posted 26 September 2018, 4:06 am EST
    I have a textbox that CANNOT grow. It cannot grow because it is part of a government form.
    That means I need to know at run time, what part of the string will run out of the text box, so I handle the rest of the string that does not fit. The width of the text box is in inches, not in pixels, so that can be challenging.
    So big letters like the capital “M” will take up more while the small “i” takes up less. Also needs to be taken into account the font and size as well. There won’t be italic and bold texts.
  • Posted 26 September 2018, 5:43 am EST
    Could you please tell which report type are your using( Section/RDL/Page). Also, you can use the “ShrinkToFit” property of “TextBox” to automatically fit the text in the desired size.
    If the above solution is not suitable for you please let me know.
  • Posted 26 September 2018, 4:13 pm EST
    That will not work. The font and size are fixed. ShrinkToFit would make the text very tiny.
    I am using version 10, SectionReport.
  • Posted 27 September 2018, 3:18 am EST
    To achieve your requirement you need to do the following thing:
    1: Convert the size of “TextBox” to pixels
    2: Check that at what amount of Text fit into the above textbox size.
    3: Get the remaining string
    You can do the above thing in “Format” event of the SectionReport
    However, 2 steps may lead to performance issue if you have a large report or too many textboxes.
    Hope it clarifies.
  • Posted 6 September 2020, 12:13 pm EST
    How do we convert the size of an Active Reports textbox to pixels? I have not been able to find any information on this.
  • Posted 7 September 2020, 6:54 am EST
    You can refer to the following link to convert the TextBox size in to Pixel:
    https://stackoverflow.com/questions/20727525/calculate-inches-and-centimeters-from-pixels-in-c-sharp
    Also, refer to the following link to use scripting in the section report:
    https://www.grapecity.com/activereports/docs/v14/online/scripts.html
