Missing "Name" property
Posted by: michael.mayfield on 30 June 2020, 4:00 pm EST
    Posted 30 June 2020, 4:00 pm EST - Updated 30 September 2022, 5:06 pm EST
    So far, I’ve done the following and still have no “Name” in the property window.
    Uninstalled v13, rebooted and reinstalled v13 with no results.
    Uninstalled v13 & v12, rebooted and reinstalled v13 with no results.
    Uninstalled v13, v11 & v10, rebooted and reinstalled v13 with no results.
    Version: 13.1.16872.0
    After about 2 hours, I need a fix ASAP.
  • Posted 1 July 2020, 12:58 am EST
    It is a known issue with the previous build. Please try with the latest build. You can download the installer from the following link:
    http://cdn.grapecity.com/ActiveReports/AR13/ActiveReports-v13.3.18800.0.msi
    Hope it helps.
  • Posted 1 July 2020, 8:13 am EST
    Initially this failed.
    Launching the solution with the default page a report GUI causes error. I closed it out the report and reopened with no errors but, no “Name” property either.
    Closed all windows and then closed VS as well.
    Relaunched VS and opened a report GUI and finally, the “Name” property is visible in the property pane.
