Moving a win forms app AR11 from Server 2008 to Server 2016 causes CAS error
Posted by: adi.shva on 12 April 2020, 11:47 am EST
  • Posted 12 April 2020, 11:47 am EST
    after moving a working windows forms app from a Windows Server 2008 R2 to a Windows server 2016 - I receive an error about CAS policy when trying to preview a report from within the reports designer. I tried following the suggestions in the forum, but after adding the required text to the app.config file - the app doesn’t start at all.
  • Posted 13 April 2020, 10:04 am EST
    I am assuming you are using the following setting in the app.config:
    <NetFx40_LegacySecurityPolicy enabled=“true”/>
    Could you please share the error message / stack trace so that we can narrow down the issue.
