Posted 11 April 2019, 4:08 pm EST
I have a simple RDL report with a nested table, the inner table has a different dataset to the outer, I have assigned the dataset the tables and doubled checked, but the inner table refuses to use the second dataset instead tries to use the outer tables instead.
When debugging the second dataset is never requested!
But if I move the nested table out to be a second primary table if you like then the second dataset is fired and data is displayed.
Any ideas?
Thanks in advance for any help.
