Posted 23 July 2021, 10:12 am EST
we have an ASP.NET Web Forms app deployed on multiple servers. After the recent upgrade of AR (we use Section Reports) from v12 to v15, our servers started to crash several times a day with the following exception which was obtained from a Windows dump.
As you can see from the attached error report, the exeption is
Key : CLR.System.IO.FileNotFoundException._message
Value: Could not load file or assembly ‘GrapeCity.ActiveReports.resources, Version=15.0.2.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff’ or one of its dependencies. The system cannot find the file specified.
This exception only occurs a few times a day and causes IIS to stop the AppPool which, then need to be restarted manually. Afterwards, the site runs fine again until the next crash. We obviously checked the versions and the license and the config files on our end and did not find any inconsistencies. The missing file is present as well.
We have opened a ticket and were told that AR15 does not support WebForms. Can anyone confirm this?
What is the latest AR version that supports .NET 4,8 Web Forms?
