.NET 5 Support?
Posted by: cliffe on 11 November 2020, 6:22 pm EST
    Posted 11 November 2020, 6:22 pm EST
    Hello, I’m just wondering whether .NET 5 is supported with the latest 14.2 version of ActiveReports?
    I have a .NET 5 ASP.NET application & was able to add the GrapeCity.ActiveReports NuGet package and add a Section Report (to a .NET Framework project & link it as per https://www.grapecity.com/activereportsnet/docs/v14/online/designing-code-based-section-reports-in-net-core.html).
    However, when I try to instantiate a report in the app, it throws an exception : Could not load file or assembly ‘GrapeCity.ActiveReports.Licensing, Version=14.2.20665.0, Culture=neutral, PublicKeyToken=cc4967777c49a3ff’. The system cannot find the file specified.
    Any thoughts on this?
    Thanks in advance,
    Cliffe
  • Posted 12 November 2020, 4:38 pm EST
    Hi again. I found that this error only happens with the latest NuGet package (14.2.20665).
    When I use 14.2.20581, I don’t get that error when I instantiate the report, but I get an error when I try to run it:
    System.IO.FileNotFoundException: Could not load file or assembly ‘System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’. The system cannot find the file specified.
    Is this something you’ve seen before?
    Thanks again,
    Cliffe
  • Posted 12 November 2020, 5:36 pm EST
    Well, I got it to work. First, I had to downgrade the NuGet packages to 14.2.20540.
    Then I had to do what was suggested on the Troubleshooting page at https://www.grapecity.com/activereportsnet/docs/v14/online/ar-troubleshooting.html under “An exception “System.IO.FileNotFoundException’ object” occurs when running a section report in an ASP.NET Core 3.1 project” (although that wasn’t the exact exception I got):
    In the project file, add
    <ItemGroup>
        <FrameworkReference Include="Microsoft.WindowsDesktop.App" />
    </ItemGroup>
    and then in Startup.cs, add
    Encoding.RegisterProvider(CodePagesEncodingProvider.Instance);
    in the ConfigureServices() method.
    Cliffe
  • Posted 12 November 2020, 10:48 pm EST
    I am glad the issue is got resolved. However, the official support of .Net 5 will come in our next major release that i.e AR15 which is scheduled to release in mid of next month i.e Dec2020.
