No bars display when Chart.Series values set via code
Posted by: raleigh on 31 October 2017, 5:06 pm EST
    Posted 31 October 2017, 5:06 pm EST
    Using VisualStudio 2013 with VB.Net and AR 11.
    Have a section report with 1 Chart control in the detail section. If i set the Chart to have 3 Series and then set the ‘.ValueMemberX’ and ‘ValueMembersY’ properties in designer…all is good. The Chart displays the bars for each of the 12 Months along the X axis.
    When i attempt to create/add the Series dynamically, in code…only the Legend is displayed. No bars are displayed on the Chart.
    I have placed the code below in the DataInitialize() and the DetailFormat() handlers.
    What might i be missing?
    Dim arChartSeries As New Chart.Series
                chartSales.DataSource = rptDataTable        'this is a System.Data.DataTable
                arChartSeries = New Chart.Series
                arChartSeries.Name = "Tasting Room"
                arChartSeries.Visible = True
                arChartSeries.ValueMemberX = rptDataTable.Columns("Month").ColumnName
                arChartSeries.ValueMembersY = rptDataTable.Columns("TastingRoom").ColumnName
                chartSales.Series.Add(arChartSeries)
                arChartSeries.Name = "Wine Club"
                arChartSeries.ValueMembersY = rptDataTable.Columns("WineClub").ColumnName
                arChartSeries.Name = "Other Sales"
                arChartSeries.ValueMembersY = rptDataTable.Columns("OtherSales").ColumnName
  • Posted 1 November 2017, 4:56 am EST
    You have to set “DataSource” of Chart after adding “Series” to the “Chart”. Please use the following modified code:
    Hope it helps.
  • Posted 1 November 2017, 12:18 pm EST
    That did the trick. Thank you for the quick reply.
