No rpx file after conversion, and designer won't load the report
Posted by: david.schrum on 19 May 2020, 4:00 pm EST
    Posted 19 May 2020, 4:00 pm EST
    I have converted a project containing several AR6 and AR7 reports to AR13. After conversion, there are no .rpx files. The designer won’t load some of the files and others cause an error when trying to load the designer into Visual Studio. The stacktrace when the designer tried to load is as follows: at System.ComponentModel.Design.Serialization.RootCodeDomSerializer.Deserialize(IDesignerSerializationManager manager, Object codeObject)
    at GrapeCity.ActiveReports.Serializer.ReportRootCodeDomSerializer.Deserialize(IDesignerSerializationManager manager, Object codeObject)
    at System.ComponentModel.Design.Serialization.CodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager manager)
    at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.PerformLoad(IDesignerSerializationManager serializationManager)
    at Microsoft.VisualStudio.Design.Serialization.CodeDom.VSCodeDomDesignerLoader.DeferredLoadHandler.Microsoft.VisualStudio.TextManager.Interop.IVsTextBufferDataEvents.OnLoadCompleted(Int32 fReload)
    Please advise …
  • Posted 20 May 2020, 5:12 am EST
    Could you please provide more detail on this issue. RPX file is deleted in your project. Or did you have the rpx and .cs file and after conversion, it becomes .cs and designer.cs file, if yes, it is design behavior. It convert the RPX file into the .designer.cs file.
    Could you please change the FW of application to 4.6.2 as AR13 supports 4.6.2 or higher FW.
  • Posted 20 May 2020, 8:13 am EST
    The framework version was the issue. Thanks Mohit.
