PageReport serialize to XML
Posted by: mdynna on 15 June 2023, 12:32 pm EST
    Posted 15 June 2023, 12:32 pm EST
    The Save method on a PageReport can be passed a FileInfo object and the result is essentially the report serializing itself to XML into the file. Rather than saving to file I would like to write this information into our database so that custom reports are stored internally. Can this serialization process be redirected into some kind of variable that I can then save to the database? I see that the method can be passed an XmlWriter object, but that seems to imply that a whole new derived class will need to be written with the logic for translating the report into XML. I would just like to have it do whatever it does when saving to file, but redirect the output. Is that possible?
  • Posted 20 June 2023, 12:03 am EST
    Hi Mark,
    Yes, you can save your report to an XMLWriter which you can store in a MemoryStream, and then convert your MemoryStream to a Byte array that you can store in your database.
    Please refer to the code snippet below:
    MemoryStream stream;
    PageReport report = new PageReport(new FileInfo(Application.StartupPath + @"\..\..\RdlReport1.rdlx"));
    stream = new MemoryStream();
    var writer = XmlWriter.Create(stream);
    report.Save(writer);
    writer.Flush();
    stream.Position = 0;
    byte[] reportBytes = stream.ToArray(); // You can save this byte[] in your database
    Please find attached a sample implementing the same.
    Anand
    MemoryStreamToByteArray.zip
  • Posted 20 June 2023, 5:10 pm EST
    Oh, I was so close! Thanks that works.
