PDF export fails sometimes
Posted by: dirk.heinze.ext on 9 July 2018, 7:20 am EST
    Posted 9 July 2018, 7:20 am EST
    Hello everyone,
    we have some troubles with generating a Report to PDF.
    The Report itself is very large and contains ~100 subreports and some Images etc. (But only about 50 pages)
    The complete report is generated by code only (creating a PageDocument and add all Report Elements to this object). Finally we render the report to different Formats like PDF, DOC, HTML etc…
    The Generation to *.doc and html works always very well. To PDF we receive sometimes an invalid/corrupted PDF. The PDF size is about 2MB in the pass case. In error case, the PDF size is <1kbyte. Also the Generation itself take a very Long time. (~100sec Here we observed, the longer the report generation takes, the higher is the probalitity to fail.)
    Did you have some knowledge about this behavior? Because this could be a showstopper for our customer solution.
    Currently we are not able to create a running code example because we are generating the report in a very complex environment.
    Currently we are using ARv12.
    Regarding,
    Dirk
  • Posted 9 July 2018, 7:54 am EST
    Could you please try the following hotfix as the pdf performance related issue fixed in this :
    http://cdn.grapecity.com/ActiveReports/ar12/hotfixes/ActiveReports-v12.1.13691.0.msi
    Hope it resolves your issue.
  • Posted 9 July 2018, 9:19 am EST
    Hi Mohit,
    thank you for the fast reply. I will try the hotfix. Currently we are using v12.1.12924.0.
    I will give Feedback as soon as possible.
    Dirk
