PDF Export FontFactory
Posted by: travis.beltrametti on 24 April 2020, 10:09 am EST
  • Posted 24 April 2020, 10:09 am EST
    We have an Azure installation using a special Font and configured Font-Factory in web.conf as to your instructions.
    We now have the issue, that with the HTTP handler the Report gets rendered correctly:
    ../Report.rdlx?OutputFormat=pdf
    But when we use PdfExport in code:
    var exporter = new PdfExport();
    exporter.Export(...);
    The fonts are not displayed. The Font factory seems to be ignored.
    Any idea why?
  • Posted 27 April 2020, 6:08 am EST
    This issue is fixed in the AR13. If you are using lower version then AR13, I suggest you to upgrade to AR13 or the latest version i.e AR14.
    An improved PDF Font Factory allows to embed end-user defined characters (EUDCs) in PDF by modifying the web.config settings. The information that you set for the end-user defined characters (EUDCs) in the web.config file will override the registry setting at the Azure Web Application deployment.
    Also, note that: For the Azure worker role project, use an absolute path instead of a virtual path in the code above:
    Hope it helps.
