Posted 20 December 2017, 9:44 pm EST
In same rpx file, when export pdf from HTMLViewer and FlashViewer is different font.
How to do to same font in both viewer.
Sorry for my poor english
Posted by: abcefg77789 on 20 December 2017, 9:44 pm EST
Posted 21 December 2017, 4:01 am EST
My Web Application is on Microsoft Azure Cloud environment.
Local environment is OK for both viewer.
Attach file for above problem.
Flash Viewer [Downloaded File]
HTML Viewer[Downloaded File]
Posted 21 December 2017, 5:39 am EST
Could you please explain the method you’re using for exporting the report to Pdf? When exporting a report using the PdfExport export filter, it doesn’t matter which type of viewer you use, the font will remain the same. I have attached two pdf files and the font is the same in both the files. Please take a look.
ReportExports.zip
Posted 25 December 2017, 12:38 am EST
I use the following code for pdf export in html viewer.
$(“#ExportSelect”).change(function (e, args) {
var valueSelected = this.value;
if (viewModel.PageLoaded()) {
switch (valueSelected) {
case “PDF”:
viewModel.Export(ExportType.Pdf, function (uri) {
window.location = uri;
}, true);
break;
case “Excel”:
viewModel.Export(ExportType.Xls, function (uri) {
}, true);
break;
And the following code is load data from sql to rpx file.
SectionReport rpt = new SectionReport();
System.Xml.XmlTextReader xtr = new System.Xml.XmlTextReader(Server.MapPath(“~”) + @"\RpxReports" + rptName);
rpt.LoadLayout(xtr);
xtr.Close();
DataSet rptDS = m_prepareRpt.LoadReportDS(rptName, rptParmas, m_dbCon);
WebViewer1.Report = rpt.Document;
rpt.DataSource = rptDS;
rpt.DataMember = “Table”;
checkViewerType();
rpt.Run();
I found the difference between document properties of pdf files.
Please check the image file.
Advice me what should I do.
I use the trial version of active report.
Posted 25 December 2017, 1:23 am EST
I copy the text from pdf to text editor.
The new problem is FlashViewer’s pdf doesn’t show the Japanese font correctly but shows correctly in HtmlViewer’s pdf.
HTMLViewer: OS タイコ ※ 鍋頭 M8×45、SW
FlashViewer : OS M8×45SW
Posted 25 December 2017, 3:44 am EST
Another problem is vertical alignment problem.
I set the bottom alignment in rpx.
But HTMLViewer shows middle alignment and FlashViewer show correctly.
Please check the pdf image file.
Posted 26 December 2017, 4:34 am EST
Thanks for the screen shots. Could you explain how are you exporting to pdf from the Flash Viewer? Are you printing to Pdf?
Posted 26 December 2017, 8:24 pm EST
Yes, I do print to pdf.
Thanks for any help you can provide.
Posted 27 December 2017, 5:33 am EST
The Save as Pdf is a feature of the browser and ActiveReports does not have control over the Print functionality of the browser. I would recommend exporting to Pdf using the Pdf ExportFilter of ActiveReports. More information about this can be found at the following documentation link - http://help.grapecity.com/activereports/webhelp/AR12/webframe.html#CustomWebExporting.html
Hope it clarifies.
