PDF Export missing .bmp image if file size is larger
Posted by: mattn on 8 June 2021, 5:15 pm EST
  • Posted 8 June 2021, 5:15 pm EST
    When exporting to a PDF if the report has an .bmp image that is too large it won’t be included in the export. I don’t know what that size limit is but I know that a 10MB file is fine and a 44MB file is not.
    Does anyone know of a file size restriction for exporting to a PDF? The viewer and printing works fine.
    Currently running AR 14.2
  • Posted 9 June 2021, 2:11 pm EST
    There is no restriction in PDF file. Could you please tell which report are you using also? Also, are you using bmp of 40 MB size in a report?
  • Posted 10 June 2021, 2:13 pm EST
    It is a page report. We are using the bmp to allow the users to “attach” a terms page to a sales order form. We embed an image so it appears as part of the report. This is done this way to support legacy functionality. Hope this explanation helps a little.
    Matt
  • Posted 11 June 2021, 2:24 pm EST
    I am able to replicate the issue at my end. Could you please share the report with us so that I can reproduce the issue at my end. You can share the report using any drive.
  • Posted 14 June 2021, 10:55 am EST
    I can share it but I’m not familiar with “any drive”. Can you give me some direction on how to get you the file. Thanks!
  • Posted 15 June 2021, 1:16 am EST
    Can you upload the file at the following link:
    https://www.dropbox.com/request/1f3lIGrFFWmTy4pziGPv
  • Posted 16 June 2021, 11:01 am EST
    Thanks! I just uploaded the report and the bmp that they are using for the last page.
  • Posted 17 June 2021, 2:44 am EST
    I am unable to use the report as I don’t have the data source at my end. I checked your image in my report but its export successfully.
    Can you please share the DB so that I can run the sample at my end. Also, check after installing the latest version from the following installer:
    https://www.grapecity.com/activereportsnet/download
  • Posted 21 June 2021, 8:40 am EST
    Thanks for trying it on your end! I’ll get up the the latest version and see if that helps. What version did you try it on so I can make sure I’m on the same page. Thanks!
  • Posted 21 June 2021, 12:34 pm EST
    I am using AR 15.1.5 at my end.
