Pre-filling information for Designer
Posted by: mdynna on 9 December 2021, 5:53 pm EST
  • Posted 9 December 2021, 5:53 pm EST
    Hi there,
    We are starting to experiment with implementing the Activereports Designer for our clients to use. In doing this we would really like to prefill a bunch of “setup” information to get our client started when making a report. I have figured out how to create a DataSource and DataSet at run-time and pass them to the report begin edited in the Designer. The last piece I need is to pre-fill the Fieldscollection so they are all available on the report. I’ve done a bunch of searching through the documentation and can’t seem to find the object or function to fill that collection?
    I did see some examples of using a DataAdapter.Fill method to do this, but that requires declaring another set of connection and command objects which seems redundant since I already have DataSource, DataSet, and Query objects for the PageReport.j
  • Posted 15 December 2021, 5:05 am EST
    Please use the Fields collection of DataSet:
    GrapeCity.ActiveReports.PageReportModel.DataSet myDataSet = new GrapeCity.ActiveReports.PageReportModel.DataSet();
    GrapeCity.ActiveReports.PageReportModel.Field _field = new
    GrapeCity.ActiveReports.PageReportModel.Field("ProductID", "ProductID", null);
    myDataSet.Fields.Add(_field);
  • Posted 15 December 2021, 1:59 pm EST
    Is there a way to loop through all the names of the columns returned by the query and fill the Fields collection using that? I don’t want to have to hard code the field names.
  • Posted 16 December 2021, 2:34 pm EST
    Unfortunately, the Fields collection doesn’t get populated on its own if the dataset is added at runtime. You’ll have to query the datasource using a DataAdapter and add the fields based on the columns returned.
